Garmin Pilot: Expanded FltPlan.com Integration and Features
Our Garmin Pilot team introduced new enhancements and features within the aviation app, highlighted by expanded FltPlan.com integration including pre-departure clearances (PDCs) and the ability to submit Electronic Advance Passenger Information System (eAPIS) manifests. Additionally, route suggestions and optimized routings are now available on FltPlan.com and can be viewed within Garmin Pilot. For our European users, Garmin Pilot incorporates a robust VFR data set including airport traffic patterns, entry routing lines, TMZ/RMZ airspaces and more.  Pilots flying IFR can manually enter or edit a route in Garmin Pilot for validation and filing via EuroControl.
FltPlan.com Premium Service Integration
Flight plans can now be seamlessly synchronized between Garmin Pilot and FltPlan.com. With Garmin Pilot version 9.7, pilots with subscriptions to PDCs and eAPIS from FltPlan.com can use these premium services within Garmin Pilot.
To get started:
Remember that all flight plans created or changed on FltPlan.com will automatically be synchronized with Trip Planning in Garmin Pilot.
FltPlan.com premium services integration
Pre-Departure Clearances*
Pre-departure clearances (PDCs) are text clearances issued for an IFR flight plan available at over 70 airports in the United States. A PDC is the same as receiving a verbal clearance from Clearance Delivery.
PDCs include:
For flights departing from airports where PDCs are available, Garmin Pilot will display the pre-departure clearance 20 to 30 minutes before the scheduled departure time.
PDCs are available from:
Electronic Advance Passenger Information System (eAPIS)*
Garmin Pilot allows users with an eAPIS premium service from FltPlan.com to enter and upload passenger and crew manifests to Customs and Border Protection.
For flights departing from the United States to Canada, Mexico and the Caribbean, a message will appear on the Trip Planning page in Garmin Pilot to notify users that a manifest is required.
Once the manifest has been successfully submitted, a confirmation message will appear on the Trip Planning page.
eAPIS
Route Suggestions & Optimized Routing
FltPlan.com route suggestions and optimized routing are available in Garmin Pilot, by:
*Note:  PDCs and eAPIS are premium service subscriptions available from FltPlan.com.  To learn more, select the “Premium Services” tab on FltPlan.com.
Optimized Routing
Widget Display Enhancements on Moving Map
When using the radial menu on the moving map, the widgets may now be moved to allow pilots to easily view airspaces, airport information, weather and more.
European VFR Data
To support the unique needs of VFR pilots flying the Europe, Garmin Pilot incorporates VFR navigation data, including:
VFR data may be displayed on the Garmin dynamic maps by selecting VFR from the map layer icon on the Map page.
Note:  European VFR navigation data is available with the Garmin Pilot Europe Standard and Worldwide Premium subscriptions.
European VFR Data
European IFR Autorouting Improvements
The European IFR autorouting feature has been enhanced to allow pilots to manually enter or edit a route in Garmin Pilot for validation and filing via EuroControl.
Note:  European IFR Autorouting is available with the Garmin Pilot Europe Premium Add-on and Worldwide Premium subscriptions.
Support for GNC 355 GPS Navigator
We recently announced the GNC 355 GPS navigator with LPV approach capabilities and a 10W Comm radio for Part 23 Class I/II and experimental/amateur-built aircraft.
Garmin GNC 355
The GNC 355 wirelessly transfers flight plans and streams weather, traffic, GPS position and backup attitude via built-in Connext technology to Garmin Pilot.
For more information about Garmin Pilot and FltPlan.com visit our website, garmin.com/aviation.
