Garmin Granted FAA’s STC for GTS Series, TAS and TCAS I Traffic Systems
OLATHE, Kan.–(BUSINESS WIRE)–Garmin International Inc., a unit of Garmin Ltd. (NASDAQ: GRMN), the global leader in satellite navigation, announced today that the Federal Aviation Administration (FAA) has granted an approved model list supplemental type certificate (AML-STC) for the Garmin’s TAS and TCAS I traffic systems, the GTS 800, GTS 820 and GTS 850. The initial AML-STC includes approximately 580 different aircraft makes and models and Garmin expects to add additional aircraft to the AML-STC in 2010. This announcement follows the technical standards order (TSO) authorization that Garmin received in November.
The GTS 800 traffic series combines active and passive surveillance data to pinpoint specific traffic threats. The systems use Garmin’s patent-pending CLEAR CAS™ technology and correlates automatic dependent surveillance broadcast (ADS-B) with radar targets to provide pilots with the most accurate picture of the sky.
“The GTS traffic series is one of several aviation products designed to be compatible with the NextGen system. It can track up to 60 targets at a time, identify the flight path of specific aircraft, and give spoken audio alerts in an ATC-like format so that pilots are able to react immediately to their surrounding traffic situation,” said Gary Kelley, Garmin’s vice president of marketing.
There are three distinct system configurations for the GTS series, and each model creates a 360-degree zone of detection around the aircraft so that pilots can see and identify targets in their airspace that may pose a collision hazard. The GTS 800 TAS is a lower-cost system offering 40 watts of transmit power and a range of up to 12 nautical miles. The GTS 820 TAS delivers 250 watts of transmit power and up to 40 nautical miles of interrogation range. The GTS 850 TCAS I satisfies all TCAS I collision avoidance criteria for higher-capability turboprops and jets. It features the same 250 watt performance as the GTS 820, and also meets the FAA’s TCAS I certification criteria. The GTS 820 and GTS 850 are installed in conjunction with a Garmin Mode S transponder.
All GTS series products include Garmin’s new CLEAR CAS (Correlated Location Enhanced ADS-B Receiver Collision Avoidance System) technology, a hybrid system that provides real-time information that is totally independent of radar-based air traffic control. CLEAR CAS combines active and passive surveillance data, including 1090 MHz Extended Squitter ADS-B data (ADS-B Out required). The system provides enhanced information that allows select displays to be updated to show flight ID, altitude, velocity, and direction of target aircraft.
Traffic information from the GTS series is displayed on the map page or traffic page of Garmin’s panel mount aviation products and integrated display systems using TAS/TCAS symbology. Additional traffic symbology can be displayed on Garmin’s synthetic vision technology (SVT) equipped PFDs. When the GTS product receives replies to its interrogations, it computes the responding aircraft’s range, bearing, relative altitude, and closure rate. Then, it enhances location data with data received from ADS-B Out equipped targets, plots the traffic location, predicts collision threats, and depicts the information on the traffic display. The system also includes expanded audio traffic alerts in an ATC-like format. For example, “Traffic; Eleven o’clock; High; Less than one mile.”
The GTS series also offers flexible antenna configurations that ensure optimum system performance for specific types of aircraft. Customers with fixed gear airplanes and rotorcraft may choose a single directional quadrapole antenna on top of the aircraft, with or without a bottom mounted omnidirectional antenna. For optimal performance on retractable gear aircraft, customers may select a top-and-bottom dual directional antenna configuration.
The GTS 800, 820 and 850 are available immediately for an expected list price starting at $9,995, $19,995, and $24,995, respectively.
About Garmin International Inc.
Garmin International Inc. is a subsidiary of Garmin Ltd. (Nasdaq: GRMN), the global leader in satellite navigation. Since 1989, this group of companies has designed, manufactured, marketed and sold navigation, communication and information devices and applications – most of which are enabled by GPS technology. Garmin’s products serve automotive, mobile, wireless, outdoor recreation, marine, aviation, and OEM applications. Garmin Ltd. is incorporated in the Cayman Islands, and its principal subsidiaries are located in the United States, Taiwan and the United Kingdom. For more information, visit Garmin’s virtual pressroom at www.garmin.com/pressroom or contact the Media Relations department at 913-397-8200. Garmin is a registered trademark and CLEAR CAS is a trademark of Garmin Ltd. or its subsidiaries.
All other brands, product names, company names, trademarks and service marks are the properties of their respective owners. All rights reserved.
Notice on forward-looking statements:
This release includes forward-looking statements regarding Garmin Ltd. and its business. All statements regarding the company’s future product introductions are forward-looking statements. Such statements are based on management’s current expectations. The forward-looking events and circumstances discussed in this release may not occur and actual results could differ materially as a result of known and unknown risk factors and uncertainties affecting Garmin, including, but not limited to, the risk factors listed in the Annual Report on Form 10-K for the year ended December 27, 2008, filed by Garmin with the Securities and Exchange Commission (Commission file number 0-31983). A copy of Garmin’s Form 10-K can be downloaded at www.garmin.com/aboutGarmin/invRelations/finReports.html. No forward-looking statement can be guaranteed. Forward-looking statements speak only as of the date on which they are made and Garmin undertakes no obligation to publicly update or revise any forward-looking statement, whether as a result of new information, future events, or otherwise.
Contacts
