Garmin® G600 Receives FAA Approval for RVSM Certification in Cessna 441 Conquest II
Garmin International Inc., a unit of Garmin Ltd. (Nasdaq: GRMN),
AeroMech of Everett, Washington, and Corporate Aircraft of Fresno,
California, today announced that the Federal Aviation Administration
(FAA) has approved a Supplemental Type Certificate (STC) package for
Reduced Vertical Separation Minimum (RVSM) certification of the G600
installed in select aircraft.
The STC package is available for G600 installations on the Cessna 441
Conquest II with an ARC 1000 autopilot, which enables Conquest II
operators to fly RVSM flight profiles from Flight Level 290 to the
aircraft’s maximum operating altitude. This allows Conquest II pilots to
gain fuel savings, lower their carbon footprint, increase range and give
them the flexibility to fly above bad weather.
“As Garmin’s premier aftermarket flight display, the G600 is the perfect
complement to the Conquest II,” said Gary Kelley, Garmin’s vice
president of marketing. “And now, with the RVSM certification, it has
even more to offer operators including the enhanced flexibility to fly
more efficiently and more safely at higher altitudes.”
“The Garmin G600 RVSM solution in the Cessna 441 provides Conquest
operators with the ability to fly safer by flying above the weather and
for less with up to a 26% less fuel burn. The G600 system provides
altitude preselect using the G600 altitude bug, further reducing pilot
workload and simplifying the scan,” said Pete Tsaris, Corporate
Aircraft’s general manager. “Working with Garmin and AeroMech Inc. was a
great experience for Corporate Aircraft and together this group was able
to develop the best possible RVSM solution for the Cessna 441.”
The G600 is a certified avionics system designed specifically for FAR
Part 23 Class I, II or III aircraft and is ideal for those wanting to
transform their panel from gauges to glass. It shows critical flight
data on two six and a half inch diagonal flat-panel displays. These
screens are mounted side by side in a single bezel that fits neatly into
the “six pack” slot of the instrument panel. The G600’s PFD shows
attitude, airspeed, climb rate, altitude and course/heading information
over a virtual terrain image with SVT™, and the MFD displays detailed
moving-map graphics of the aircraft’s current position in relation to
ground features, chart data, navaids, flight plan routings and more.
Installations of RVSM-compliant G600 avionics may be completed at a
Garmin authorized dealer. G600’s that are certified for RVSM will
include the GDC 74B air data computer, altitude pre-select, and other
required hardware. Pricing for the equipment and STC package will begin
at approximately $80,000.
About Garmin International Inc.
Garmin International Inc. is a subsidiary of Garmin Ltd. (Nasdaq: GRMN),
the global leader in satellite navigation. Since 1989, this group of
companies has designed, manufactured, marketed and sold navigation,
communication and information devices and applications – most of which
are enabled by GPS technology. Garmin’s products serve automotive,
mobile, wireless, outdoor recreation, marine, aviation, and OEM
applications. Garmin Ltd. is incorporated in Switzerland, and its
principal subsidiaries are located in the United States, Taiwan and the
United Kingdom. For more information, visit Garmin’s virtual pressroom
at www.garmin.com/pressroom
or contact the Media Relations department at 913-397-8200. Garmin is a
registered trademark, and SVT is a trademark of Garmin Ltd. or its
subsidiaries.
All other brands, product names, company names, trademarks and service
marks are the properties of their respective owners. All rights reserved.
About AeroMech Incorporated
AeroMech Incorporated, an FAA STC ODA, specializes in aircraft
engineering and certification services, including RVSM for aircraft
OEMs, modification shops, and owner/operators. Since its inception in
1995, AeroMech has completed over 140 STCs, 450 flight-tests, and
successfully certified more than 6,500 commercial, military and business
aircraft through 19 regulatory agencies worldwide. In addition to its
engineering and certification services, AeroMech also provides avionics
kits and full service on-site aircraft modification services through its
subsidiary, AMI Aviation Services, LLC www.amiaviation.com.
For more information, visit www.aeromechinc.com
or contact AeroMech at 425.252.3236.
About Corporate Aircraft
Corporate Aircraft’s extensive sales and service knowledge of the
Conquest lines, 30+ year relationship with Cessna as an authorized
Propjet Service Center and staff of service specialists who have
maintained these types since they rolled off Cessna’s production lines,
have made them a premier provider of Cessna PropJet support services
recognized throughout the world.
Notice on Forward-Looking Statements:
This release includes forward-looking statements regarding Garmin Ltd.
and its business. Such statements are based on management’s current
expectations. The forward-looking events and circumstances discussed in
this release may not occur and actual results could differ materially as
a result of known and unknown risk factors and uncertainties affecting
Garmin, including, but not limited to, the risk factors listed in the
Annual Report on Form 10-K for the year ended December 25, 2010, filed
by Garmin with the Securities and Exchange Commission (Commission file
number 0-31983). A copy of such Form 10-K is available at www.garmin.com/aboutGarmin/invRelations/finReports.html.
No forward-looking statement can be guaranteed. Forward-looking
statements speak only as of the date on which they are made and Garmin
undertakes no obligation to publicly update or revise any
forward-looking statement, whether as a result of new information,
future events, or otherwise.
About Garmin International, Inc.
Garmin International Inc. is a subsidiary of Garmin Ltd. (Nasdaq: GRMN). Garmin Ltd. is incorporated in Switzerland, and its principal subsidiaries are located in the United States, Taiwan and the United Kingdom. Garmin is a registered trademark.
All other brands, product names, company names, trademarks and service marks are the properties of their respective owners. All rights reserved.
This release includes forward-looking statements regarding Garmin Ltd. and its business. Such statements are based on management’s current expectations. The forward-looking events and circumstances discussed in this release may not occur and actual results could differ materially as a result of known and unknown risk factors and uncertainties affecting Garmin, including, but not limited to, the risk factors listed in the Annual Report on Form 10-K for the year ended December 26, 2020, filed by Garmin with the Securities and Exchange Commission (Commission file number 0-31983). A copy of such Form 10-K is available at http://www.garmin.com/aboutGarmin/invRelations/finReports.html. No forward-looking statement can be guaranteed. Forward-looking statements speak only as of the date on which they are made and Garmin undertakes no obligation to publicly update or revise any forward-looking statement, whether as a result of new information, future events, or otherwise.
Contact
Carly Hysell
Phone | 913-397-8200
E-Mail | [email protected]
Public Company Information
NASDAQ:GRMN
