![](https://www.garmin.com/en-US/newsroom/wp-content/uploads/2020/11/GFC_600-2C_G5-2C_TXi_-_Bonanza.jpg)
Garmin® provides key updates for TXi flight displays, GTN navigators, GFC autopilots and the G5 electronic flight instrument
Adds descent VNAV, G500 TXi compatibility with G5 & GFC 500 and other enhancements
Garmin International, Inc., a unit of Garmin Ltd. (NASDAQ: GRMN), today
announced it’s adding significant capability, more configuration options
and offering greater integration throughout the GTN™ 650/750 touchscreen
navigators, the G500 TXi/G600 TXi and G500/G600 flight displays, as well
as the GFC™ 600 & GFC 500 autopilots. Additionally, the G5 electronic
flight instrument for certificated aircraft is being approved for use as
a standby instrument when paired with the G500 TXi or G500 flight
displays. The GFC 500 autopilot will also be approved for installation
with the G500 TXi or G500 flight displays, while the addition of descent
vertical navigation (VNAV) within the GTN will aid in descent planning.
With Garmin, pilots receive a seamlessly integrated cockpit that offers
a more harmonious transition among avionics, which reduces pilot
workload and provides a superior in-flight experience.
“The Garmin avionics ecosystem continues to provide pilots with
optimized upgrade opportunities and unsurpassed capabilities within the
cockpit,” said Carl Wolf, vice president of aviation marketing and
sales. “We are committed to providing pilots with scalable,
value-oriented solutions when selecting their panel configurations. For
customers with these products currently installed, these software
updates offer greater operational potential and a broader feature set
than any other avionics solution on the market.”
GTN 650/750 descent vertical navigation
To assist in descent planning and energy management, pilots can take
advantage of VNAV profiles throughout the enroute and terminal phases of
flight within the GTN 650/750 touchscreen navigators when they’re paired
with the G500 TXi/G600 TXi, G500/G600 or G5. Within the GTN, pilots can
easily enter altitude constraints on the flight plan page to set-up a
vertical descent profile. Pilots also experience a near-seamless
transition from VNAV to an arrival and instrument approach. Once an
arrival or approach is loaded and activated, the GTN automatically
populates step-down altitudes or any applicable altitude restrictions.
If ATC issues an unpublished altitude restriction, pilots can enter
those altitudes manually into the active flight plan under the VNAV
field.
As part of the VNAV profile, top of descent (TOD) and bottom of descent
(BOD) values are also calculated and displayed on the moving map. As the
aircraft arrives at TOD, the GTN displays a visual annunciation
prompting the pilot to begin the descent. When paired with a display
such as a G500 TXi/G600 TXi, G500/G600 or G5, a vertical deviation
indication (VDI) also populates on the display to provide vertical
guidance for the descent. Additionally, when the GTN 650/750 series is
paired with the GFC 600 or GFC 500 autopilot, pilots can select the VNAV
button on the mode controller to fly a fully-coupled VNAV profile.
Approved as a standby: G5 electronic flight instrument
The ever-popular G5 electronic flight instrument will soon be approved
as a standby flight instrument when paired with the G500 TXi or G500
flight displays. In doing so, any adjustments made to heading bugs,
altitude select, airspeed bugs, as well as the barometric pressure
setting are automatically synced from the G500 TXi or G500 displays to
the G51. Flight director and autopilot mode annunciations
from the GFC 500 can also be viewed across all displays, including G5.
Over 600 aircraft will be approved for the installation of G5 as a
standby flight instrument alongside the G500 TXi or G500 flight displays.
GFC 500: Now approved for G500 TXi and G500-equipped aircraft
Aircraft owners can soon pair the economical GFC 500 autopilot with the
G500 TXi or G500 flight displays, offering a fully-redundant, all-glass
cockpit when paired with the G5. For example, in the unlikely event of a
G500 TXi flight display failure, the G5 will remain coupled to the GFC
500 autopilot and continue to fly normal autopilot modes, including
altitude select, heading, vertical speed and more. This compatibility
significantly reduces pilot workload.
Course deviation indication (CDI) and VDI preview
A popular feature in turbine class aircraft, a CDI preview option allows
pilots to view course and vertical deviation information prior to an
instrument approach. When the GTN series is paired with the
G500 TXi/G600 TXi or G500/G600, pilots can view this feature within the
HSI or lateral deviation indicator on the flight display. When GPS is
the selected CDI source, information such as a course pointer, lateral
deviation, station ID and the numeric inbound course automatically
populate on the HSI in gray when an instrument approach is loaded. For
ILS and GPS approaches with vertical guidance, a preview of the VDI also
populates on the TXi series, G500/G600 or G5, allowing pilots to view
glideslope or glidepath deviation prior to the descent.
Garmin Pilot™ and Engine Information System (EIS) analytics
Exclusive to Garmin, customers can now utilize Garmin Pilot on Apple
mobile devices to view real-time engine information via Flight Stream
510 when the app is paired with an EIS-capable TXi flight display or the
G1000® NXi integrated flight deck. Upon landing, the flight
data log is wirelessly uploaded to the flyGarmin® website and
is stored securely within the app and on flyGarmin. Within the flyGarmin
website, pilots can access detailed information related to any flight,
play-back the flight and download data logs.
New TXi display orientations, configurations and capabilities
The TXi family adds even more options, such as:
The 10-inch TXi flight display can be configured to a 40% PFD and 60%
MFD split-screen layout. -
On a 7-inch portrait or landscape G500 TXi/G600 TXi, the displays can
be configured to view moving map and single-engine information
simultaneously. -
The 7-inch landscape TXi display can be used as a PFD, adding
installation flexibility in aircraft panels that are space-limited. -
With a compatible camera, pilots can optionally display multiple video
inputs on the MFD of a TXi display. -
Within EIS-capable TXi displays, pilots can select and view individual
cylinder head temperature (CHT) values.
GTN 650/750 series enhancements
The GTN 650/750 touchscreen navigators also incorporate a variety of
additional features, including:
The addition of new audible and visual terrain proximity alerts,
including “terrain ahead, pull up,” “obstacle ahead, pull up” and
“wire ahead.” An aural “five-hundred” annunciation is also available
when the aircraft is on approach to land. -
Pilots can now set a user-defined waypoint as an airport so terrain
alerts are minimized while landing at an airport that is not in the
aviation database. -
The addition of a QWERTY keyboard within the GTN 650/750 and the G500
TXi/G600 TXi gives pilots a more familiar way to input information. - Pilots can configure COMM sidetone settings within the GTN series.
Irish, Swiss and English coordinate systems are now supported so it’s
easier for pilots to enter GPS coordinates in various formats,
including latitude/longitude, degrees/minutes/seconds and decimal
degrees. -
The new GWX™ 75 weather radar is now supported by the GTN touchscreen
navigators and the G500 TXi/G600 TXi flight displays, which offers
four-times more color contouring than typically found on other weather
radars on the market.
These software updates are expected to be available in August from
Garmin Authorized Dealers for hundreds of aircraft makes and models.
These updates are available from Garmin at no charge. A dealer
installation charge may apply. Garmin avionics are supported by Garmin’s
award-winning aviation support team, which provides 24/7 worldwide
technical and warranty support. Garmin will be showcasing these new
features and configuration options next week at the 2018 EAA AirVenture
fly-in, in Oshkosh, Wis., July 23-29, 2018. For additional information,
visit www.garmin.com/aviation.
Garmin’s aviation business segment is a leading provider of solutions to
OEM, aftermarket, military and government customers. Garmin’s portfolio
includes navigation, communication, flight control, hazard avoidance, an
expansive suite of ADS-B solutions and other products and services that
are known for innovation, reliability, and value. For more information
about Garmin’s full line of avionics, go to www.garmin.com/aviation.
For decades, Garmin has pioneered new GPS navigation and wireless
devices and applications that are designed for people who live an active
lifestyle. Garmin serves five primary business units, including
automotive, aviation, fitness, marine, and outdoor recreation. For more
information, visit Garmin’s virtual pressroom at garmin.com/newsroom,
contact the Media Relations department at 913-397-8200, or follow us at facebook.com/garmin,
twitter.com/garmin,
or youtube.com/garmin.
About Garmin
Garmin International Inc. is a subsidiary of Garmin Ltd. (Nasdaq: GRMN).
Garmin Ltd. is incorporated in Switzerland, and its principal
subsidiaries are located in the United States, Taiwan and the United
Kingdom. Garmin, G1000 and flyGarmin are registered trademarks and GTN,
GFC, Garmin Pilot and GWX are trademarks of Garmin Ltd. or its
subsidiaries.
Apple is a trademark of Apple Inc., registered in the U.S. and other
countries.
All other brands, product names, company names, trademarks and service
marks are the properties of their respective owners. All rights reserved.
1. Requires the GAD 29B adapter. Synchronization features only
available when the GFC 500 autopilot is installed.
Notice on Forward-Looking Statements:
This release includes forward-looking statements regarding Garmin Ltd.
and its business. Such statements are based on management’s current
expectations. The forward-looking events and circumstances discussed in
this release may not occur and actual results could differ materially as
a result of known and unknown risk factors and uncertainties affecting
Garmin, including, but not limited to, the risk factors listed in the
Annual Report on Form 10-K for the year ended December 30, 2017, filed
by Garmin with the Securities and Exchange Commission (Commission file
number 0-31983). A copy of such Form 10-K is available at www.garmin.com/aboutGarmin/invRelations/finReports.html.
No forward-looking statement can be guaranteed. Forward-looking
statements speak only as of the date on which they are made and Garmin
undertakes no obligation to publicly update or revise any
forward-looking statement, whether as a result of new information,
future events, or otherwise.
Contacts
